Topic: Tube flattening from bending process
Hello everyone,
it's been a while since I've posted but I'm back and trying to make progress on my slow build again.
I've recently tested my tube bender with a piece of ERW tubing and I'm concerned about how much flattening I'm seeing on the outside radius of the curve. I plan to use DOM tubing for the cage but I figured for practice / testing / measurement purposes there would be no discernable difference with ERW.
Am I wrong? would the exact same dimension tube in DOM resist flattening better than ERW? I'm using (and had intended to use for my build) 1.75 x .095 tubing and I already know I can mitigate the flattening by using .120 instead. And I've already sent pictures of what I've got to Pagel so if he says mine are too squished that's exactly my plan.
But in the meantime, does anyone know, or would be willing to measure, what is an acceptable/normal amount of flattening of the tube around a curve? I put a caliper across my test piece in the middle of the bend and what was 1.75" tube is now 1.625". Am I just paranoid or is this trash?
