Topic: 2006 Mustang (S197) Roll Cage Question
We are putting a roll cage into a 2006 Mustang (S197) and there is very little space between the back of the driver's seat and the area where the floor pan goes up under the back seat. If we move the vertical roll bar as far back as it can go, the back of the seat is basically touching the roll bar and the sides of the seat is touching the roll bar. We have three choices it seems:
1. Put the roll bar down to the lower floor pan as far back as possible and have the seat right up against the rear cross bar
2. Lean the vertical roll bar about 15 degrees and follow the B-pillar up.
3. Put the roll bar further back and attach it to the "higher" part of the floor pan that was formerly under the back seat.
If you have a S197 Mustang with a roll cage that passed Lemons Tech - any advice would be much appreciated
Thanks. in advance.
-- Chuck
SakaiCar Neon 42
