Topic: Electrical Cut Off Questions - Location and Wiring
While I’m waiting on the cage to be built, I’m trying to figure out the proper location and wiring for kill switch. We were thinking of putting it next to the seat, at the green circle. Easy for the driver to access and easy for someone outside to reach it. That would be fine, right?
As for wiring it, at first it seemed like we could put it in between the positive line on the battery. After lots reading, it seems like we’d also need to run a line from the alternator. Originally we bought a 2 pole switch, but now need a 4 pole? Slightly confused on how to properly wire the kill switch without hurting components. Anything helps, thanks!
