Judge Sam wrote:Crab Spirits wrote:Counting the minutes till I see this car in person.
+1
the good news is the car is definately done enough that it's getting shoved on a trailer and brought up there to show. but if anythimg major goes wrong at this point, it's gonna be a show stopper.
anyways, onto tonight's progress...
1) hooked up the shifter... those cheap push pull cables from mcmaster car are simply atrocious. they have more slop than the travel to select gears. it isn't anywhere near right, but it can be shifted in every gear except overdrive so it's getting called "good enough for now"
2) i plumbed up the oil tank up front. waiting for the brackets to show up to mount the tank.
3) added the extra throttle return spring to make everything feel right.
4) mounted cht probe. the 18mm plug CHT sensors were too expensive so i placed it around a head/jug bolt. it should be right at the hottest part of the head there anyways so the reading will be "good enough"
my list is down to the following:
1) megasquirt
a) wire in O2 sensor
b) tune it some more (though i have most of the smoke gone now, i need to make a new video)
2) brakes, i need to make a 2nd vac manifold to power the brakes and for the fuel tank evap lines
3) cooling fan mount/ main prop nut locking aparatus. i think i can make both of these functions as a single part.
4) mount tach, fuel and head temp guages
5) safety
a) wire up brake lights
b) get a fire extinguisher
c) install 5-pt harness
d) rear view mirror
6) add steering wheel/brackets
7) make CV shaft spacers. it looks like i may have made my shafts a bit short but a small spacer will make it work just fine.
8) deal with the damn clutch
a)it looks like the throwout still isn't right.
b)get a hydraulic line made
9) order tires
10) replace windshield (spider cracked it while installing the cage... damnit)
11) add in extra engine supports for front mount to prevent flywheel from touching crossmember. perhaps add shims between crossmember and body to help there also.
i think that is it for now
