Topic: EFI Tank donor for Lemons Rally
I'm looking to retrofit a different fuel tank into my Opel Kadett to support an EFI conversion and because I don't like the tank it has now, in the right rear corner of the cargo area. With all the fuel tanks you have looked at, do you guys know of a good one that would fit in this space?
https://qkzvjq.by3301.livefilestore.com/y3mInmIC4BW-izGzhJ4lD8SBCjBSvHf-lu2ak3UdZM9VmyXKkOcvubPgXPTdWBZaE7iFbyMiopWGBmGV0Pewp0CC9elbdLcnqvPfJCVV3ey5CdiBOz0Pbk5z86fl84BNOSiwNLKIJ3EDFjSuDCYouACr1yxq7XeGhJwTX7pANL_TNw?width=1024&height=765&cropmode=none
Under that flat deck, there is a cavity where I would like to recess a different fuel tank - it's 6-8" deep, I can cut out the floor to set the tank lower, and I can build mounts off the frame rails. I got to looking into universal tanks, and this one from tanksinc looked nice, but I would be into it $400+ to buy one brand new set up for EFI. I would prefer to go the junkyard route.
https://p0bwmq.by3301.livefilestore.com/y3mNs23ioDBCjQ2o3P2aPBiIstVPtv38twdIuzxLzYIPQWDspbM0HXbY9d9eAR3d2oITNsyIFjzW2k4wGtkNIT7eJr2zgUN1hTRiVY7bCK10snUPlYnaOT58osEZraR2KffzZIdQUWcKipRolAkjwaFi-Aj7KI29PihGWUUQOYOHF8?width=319&height=185&cropmode=none
https://q0zvjq.by3301.livefilestore.com/y3m4J31uW86EwH9DRjjp5s2-QxTpX-4s4rgRsXwla2lT9BsNUlbP7icGgRORsuMiSFyTIpu5Wgt1csije8PiDTGDIWVhzRaRpXVMHRz3jDUaT_-GyCCUuVG3TP6RDbTfaxjN5atIPfqKPJ-y_rxmnmRRAgvvD2UMPeJnTnCCNTnDdY?width=1024&height=576&cropmode=none
I used to do a lot with Isuzu Troopers, I had saved a tank for a while thinking I would use it in the Opel, but I may have accidentally sent it to the scrappers. That tank was big at 21 gallons, but I liked how they mounted between the frame rails and the fill tube pointed the correct direction. I would be fine with something in the 16-ish gallon range. I do know a guy with a parts Trooper, so I could get another one if I need. This is what they look like (after being nicely cleaned and painted).
https://pubwmq.by3301.livefilestore.com/y3m4HzzPVWLauTn3p5w0kARrFPTYPcYa5bltLRN5eOKyo9qLXjfSjOpfK0EPCSJ9tCxf5jaSKqDWQff93JjAYBmtPYfUuhoAfn9V3NOtHpatzqhg-mMNxw9S6xpTuLhQ98qUvLjystZA66ZH8gwsyLAJphSXDC03eYNnIlASLqMR6w?width=1024&height=768&cropmode=none
https://rkzvjq.by3301.livefilestore.com/y3m0EZCHlGSnL3EvBxmQsvyd-HFNfpqsfVdNQdSN4JD1w_B2u7SOt2ElFpvIswXfyZBbHXL7IDtUFPT0DzbwlXoxVKP3_rzoDjVFa6Udzf0Io9HdRm5olSZiJA3HWs4XIwQy1fo-x_QY_WpO0tunRCSNG1CoapZIlJoqCrd2ip4tCc?width=1024&height=768&cropmode=none
Next Rally Car: An abandoned 1972 Opel GT (Plan-B: My late grandparent's 1996 Chevrolet Caprice Classic)
Previous Rally Cars: 1971 Opel Kadett, 1988 Chevrolet Cavalier Z24, 1998 Volvo V90 (5.0L), 1965 Ford Galaxie 500 (turbocharged 351W)
Re: EFI Tank donor for Lemons Rally
Sputnik still has a fuel tank from Nissan Quest, looks like roughly that shape. Comes with a working pump and sender. Come take it wink
K Car Stalker
Check with Evil Genius.
I think that you can either run the factory tank or an aftermarket cell but not another factory tank from another make/model.
Overall winner Gingerman 2019
Headline of the post says it's for the rally so that won't apply otherwise you're right.
Owner of the Traveling Hat
Good catch!
I just assume Lemons racing when i see these questions, it's good that we are branching out as there is a lot of combined experience and expertise here.
Correct, this is for the Lemons Rally, not the race. I do aim to make it safer than the OEM arrangement.
I've been browsing pictures of random fuel tanks, ones from SUVs have the frame mounting that I prefer, and that lead me to search for a Geo Tracker tank. It's only 11 gallons, which is only slightly larger than the OEM tank, and I would expect that it would fit the space well. $50 from a junkyard. It's an option.
https://pkaldg.by3301.livefilestore.com/y3mRPneD7wpqE2yqYP0f7bzagBivpEVuhow819C-7x7_mAeBTITWu-GQFx-n9yD8lHjRXkEwcBjCRVrzM2R1iHUenxtNIPojqEqo7iNovXlMrDmOvj2wsbgvXYcsqtPUN8cYJufVPU0vNEtntjQhX01TdhfSSsMH2DrVnnMdRHuoMY?width=1024&height=1024&cropmode=none
Or something wider, flatter, and larger capacity is a late 80's Subaru GL/Loyale tank.
https://p0aldg.by3301.livefilestore.com/y3mgN62GTfksswIPyMy8xtkWdWxbht8swoJm4VELa_z-ldnQLd2KpcRDoDTBTUmKvqEIVzzMtQOdUpnSvJb3tpcmmMHuba7aeGuwRk0UuTbvkd4mLLTMCzPPXZL4EWDHInu1gNYMql3E84a_YTnED54scjDBuP0gv9c8BBEN492zA8?width=800&height=800&cropmode=none
See where I'm going with this?
That area looks similar to the stock location for a 2001 VW Golf/Jetta tank.  I have an extra if you wanna come get it...
Nick
Focke Ewe racing -> Muttonheads! Racing -> Torque Junkies
86ish VW GTI...now with TDI Powah!
