Topic: Plinth box for rear stays?
Anyone ever used plinth blocks for the rear spreader plates? I had a friend ask me about it and I have no idea if this would be acceptable. Just curious what you all think.
http://i1142.photobucket.com/albums/n613/cabinboy63/received_102114368453721101.jpeg
http://i1142.photobucket.com/albums/n613/cabinboy63/received_102114370570174011.jpeg
Owner of the Traveling Hat
Re: Plinth box for rear stays?
I can't see why it would be an issue. You can use them everywhere else. Make sure you use the required 1/8" thickness plate.
However for extra piece of mind I'd have that lower piece also be a bent piece that runs up the vertical surface. That's how I built the boxes for the Saab.
http://i174.photobucket.com/albums/w116/cegan09/saab%20build/20160921_221901.jpg
That's what I told him. My main concern was that I've never seen it done before.
As always if you're really concerned ask Jay/Pagel. But I don't think they'll have a problem with this.
I have rear plinths in my car.  No issues with tech.  I think they are perfectly acceptable.
Looks good.
You won't gain any suspension stiffness, though.
Unless they're over a subframe mount. Tied to your
upper strut mount area helps stiffen them.
Also, how is you angle? Is it close to the required approx. 45 degrees?
Capt. Delinquent Racing
DelinquentRacer wrote:
Looks good.
I have no idea. Not my car. I was just asking for a friend.
They have to be totally boxed,  front, back all around, welded 360 degrees  with no burn through and be at least 1/8" thick
-John
