Re: Can't keep the Saab Cool
Car is obdii, so unless it's chipped removing the cat might make less power from it throwing a cat code if it goes into a limp mode. It might be fine with the check engine light on and making more power too, depends on the tune. Or chip the ecu with a tune that ignores the cat. If the cat is clogged or partially clogged that could be the extra heat.
You can vent the hood about 1/3rd of the way back from the front edge. You can also add a Gurney flap (aka 3/8 or 1/2" aluminum angle) to the front edge of the cut to help it suck the hot air out. Put it in the wrong spot and you will be forcing air into the engine compartment instead of out, so do your research before cutting.
I'll echo the mention of making sure there's no air in the system. Easy to get air trapped in some cars. Vacuum cooling system filling setups are great. Some have bleeders in the high spots to help purge air.
Some water pumps are junk. the impeller / bearings can feel good cold but the impeller can slip once they're hot.
Any chance you're running strange ignition timing or fuel out of the tunes window? Retarded timing dumps tons of heat in the cooling system. You could log obdii data and see how much timing it's pulling. Also worth looking at what it's doing with fueling and see if knock is happening in specific cylinders. Might be worth trying higher octane or a bit more ethanol in the mix if it's not going lean.
