Topic: Miata Harness Bar Height
So this is a cross post from the noob section. Want to make sure I get some input while we have time to work on it. Won't let me link to the other post 'cause I'm too new to the forums, so here's the question.
Thanks!
So our team has a 6'4" driver and me, at 5'8". We had to lower the seat to fit tall guy. With the dropped seat, the harness bar is just level with my shoulder. Checking the docs on the harness install, the harness bar/restraint height is supposed to be a 0 degress to -20 degrees below the driver's shoulder.
So here's the question. Am I going to pass tech here, or do I need to sit higher? If I need to sit higher, can add some SFI padding to the seat or would I need to raise the seat itself?
