Topic: Car Choice - 2002 VW GTI 1.8 T
Looking at a cheap VW GTI w/ a 1.8T motor the the NJ Lemons race
Does anyone have insight on the durability of this engine? thoughts, suggestions?
This is will be our first Lemons race any insight appreciated..
The 24 Hours of Lemons Forums → Lemons Newcomers → Car Choice - 2002 VW GTI 1.8 T
Paging Tom Lomino.....Mr Lomino are you there....
There are plenty of VW guys that can assist here.
We just ran one in a 50 lap Dirt Enduro......Ran Great, But a short sprint race is not a great Lemons grade test bed.
Manny
VWs of all flavors have proven to be consistently quick until they almost inevitably break. As the MK4 was probably a quality low point for VW, the combo will probably be fun right up until it isn’t, every single race. At least parts cars are readily available and cheap.
Bring spare coil packs. You probably also want to bring a spare junkyard turbo.
The engines are OK until they ventilate the crankcase. Do not increase boost if you want it to live a long life.
We ran one for a few races last year and now graduated that car to AER duty. longblock is rock solid reliable as long as the turbo and other components hold up we pretty much have the turbo fall off every day of racing. We replace with OEM hardware after each day to stay ahead of inevitable failure even when all seems when it will sometime just let go. Other than that it east wheel bearings alot. The faster you go the faster it eats them. One Lemons race on the fronts about and one day at AER race approximately Very fun car though when well sorted out. Loves the rain.
Do it. Thats a good motor if you take care of it. Yes be ready to swap wheel bearings regularly once you get the hang of using the cars cornering ability. FWD is a great way to start and learn all about the limits of adhesion.
I'm making up a MK3 Jetta VR6 for my first Lemons car. Just got it two months ago or something like that and finally started prepping it. I've been doing a lot of the internet warrior reading and yeah, lots of people mention the wheel bearings. I'm probably over prepping but since I've got spare parts at the house I'm going to replace the wheel bearings and bring an extra set of spindles that have a new set pressed into them. One or two people mentioned putting better grease in them, like aircraft grade. One guy for my car said to swap to MK4 rear bearings because they are bigger and last longer. I was wondering if putting some air flow over the whole spindle would help keep temps down and allow them to last longer.
I got a pretty crazy good deal on this Jetta from a VW guy in the next state from me that his wife was trying to get rid of a lot of his stuff so he unloaded three boxes of parts with the car.
I'm not sure if the MK4 rear beam is the same as the MK3 in design but you can weld a piece of metal into the C shaped channel of the beam to make a cheapo rear sway bar. I plan on doing that to combat some of the under steer. I just don't know how much to weld in and how thick of metal to use. Gotta do some more reading\asking around.
Good luck with the car and race!
We've been meaning to put a piece of laundry tube from the front air dam to the spindle. And yes the idea being to keep the heat of the rotors away from the bearings. Scene it done on many a car but couldn't confirm the benefits yet.
