Topic: E46 overheating
At CMP for testing,  and car is overheating after 10 minutes on track. History: it overheated at the spring race, took it home had compression and leak down tests done on the engine and pressure test on the cooling system.  No issues found. Replaced the expansion tank.  Only overheats when racing, can idle for an hour with no issues.
Any thoughts or ideas welcome, otherwise our weekend is over.
Re: E46 overheating
Has the car ever run on track without it overheating, or is this new behavior?
Compression test only tells you that you have a good seal at the rings and valves. Pressure test on the cooling system will only tell you that there are no coolant leaks, it doesn't tell you how much flow you are getting.
You are getting enough coolant flow to handle the heat load generated when idling. When you run on track, you need more coolant flow to overcome the additional heat load.
Bad water pump, collapsed/blocked heater hose, partially plugged radiator, limited air flow path in/out of the radiator spring to mind. We had a radiator that got partially plugged and exhibited that exact behavior (ok at idle but too hot when running on track). We diagnosed it with an infrared thermometer pointed at the radiator surface, we saw different temperatures across the face of the rad (cooler where it was plugged because no hot water from the engine was getting to that part).
We swapped radiators and the problem went away.
Do you have any spares with you? The above items should be easy to replace and check (if you have any). If you have a blockage internal to the engine, not so much.
We Audi Be Faster
Re: E46 overheating
We ran barber this winter without problems, and spring CMP started fine, but the expansion tank cracked so had to replace. It hasn't tracked without overheating since.
Re: E46 overheating
Sorry to say you probably are jobbed.  We did this dance with our E46 after it cracked its expansion tank.  Blown head gasket.
Re: E46 overheating
Simple check for other than cooling system overheating issue.  Get it hot but not overheating.  Pull in.  Since you have a pressure cap on your overflow (actually expansion tank), put on a welding glove and take it off while running. After the shit settles down (about 3 minutes) watch for bubbles or oily bits in the expansion tank.  ANY bubbles (almost always tiny) and the headgasket is blown.
Re: E46 overheating
Agree that bubbles in the radiator is a sure sign of a head gasket. But you don't need to go on the track or open a hot radiator. Just take a piece of cardboard and stick it tight to the radiator in front of the fan. Take the cap off the radiator. Start the car and heat it up. Watch the water temp and watch for bubbles in the radiator. If the car won't heat above 210 sitting at idle with the radiator covered with cardboard then have someone sit in the car and up RPMs to 1500 - 2000 for ten minutes or until temp gets to about 220 - 225. No bubbles, probably not a head gasket.
Not sure what year the car is but the newer years of that gen have an overheat tattle tail on the head. Look for a circular piece of stamped metal about the size of a dime flat on the head at one of the corners. If that piece exists and is curled or deformed then you have a head gasket and a warped head. Don't waste you time and money replacing the head gasket until you take the head to the machine shop.
Re: E46 overheating
^ this is all fine and dandy but we went through the exact same symptoms with our Lemons E46 after a cracked expansion tank.  Wasted a couple races after everything checked out "fine". Blown head gasket.
Re: E46 overheating
Honestly pull the head, check to see if it's straight.  If straight have machine shop clean it up then stud the head for cheap insurance.  Leave stock rev limiter on it to prevent over rev's
Re: E46 overheating
When you replaced the expansion tank, did you bleed the cooling system using the process recommended by bmw?  Before pulling the head, I’d try to bleed it again.
Re: E46 overheating
Bad water pump would be a good thing to check some years have plastic impellers that crack and spin on the shaft at higher rpms. . Also gut the thermostat and block off the heater core.
There were a lot of "interesting" suggestions how to check the headgasket. Best bet is just leave pressure on it with your cooling system pressure tester overnight. Pull plugs and look for water in the cylinders. You can get it up to temp with the tester on there 1st if you really want.
If you do have water in the cylinders just buy another engine off ebay. To do a headgasket properly you will have to drill and timecert the block using a jig. Otherwise the head bolts will just pull out of the block. (If they haven't already)
PM me if you need help. I race one. Own a few. And work on BMWs for a living.
and now the #95 Thunderbird
Re: E46 overheating
Bleeding all the air out of BMW straight six cooling systems is always critical.  Maybe you will get lucky and a simple bleed will do it.  I always jack up the corner of the car that will raise corner of the engine closest to the expansion tank to help air bubbles find their way home.
In reality, any aluminum block M5x that has ever been overheated should receive a full complement of Timeserts.  Do not install just one for a single stripped bolt.  Timesert every bolt.  Buy, borrow, or steal the BMW specific fixture/kit and use the correct length inserts (24.5mm?).  The standard M10 Timesert kit comes with inserts that are too  short.  This advice was given to me by a reputable indie mechanic in Chicago who used to do several M54 blocks a month.
Note that Timeserts are the preferred insert for repairing BMW blocks.  They actually have an oversized insert kit for blocks with failed Helicoils (too short?).
I do not endorse this LeMony thread repair for M5x engines using non-factory bolts.  I only offer it for your evaluation.  Read at your own risk.
https://southeastcylinderhead.com/alumi … ad-repair/
http://www.ducttapemotorsports.com/
http://www.teamdfl.com
"I can see it now, a pile of nickels and all the glory of being a real race car driver."
Prepping the Red wReck for the 24 Hours of Lemons
