Topic: Camera mounts
What are acceptable ways to mount a camera inside a care? Also, what are unacceptable ways?1st timer here and just want to make sure we do it right
The 24 Hours of Lemons Forums → Lemons Newcomers → Camera mounts
The best bet is to use a roll bar mount system from either the camera manufacturer (if an action cam), or RAM Mounts.
Unacceptable ways include but are not limited to:
Zip-tieing a camera operator to the cage to hand hold the camera
Duct Tape
A free standing tripod
Some tracks do not allow helmet mounted cameras.
Bill
Video from a helmet mounted camera is nauseating anyway, I loathe video from that perspective.
Ideally they should be hard mounted. Meaning purpose built mounts using normal fasteners. Roll bar mounts are the best and they're available everywhere for common cameras like GoPros.
There are really really good suction cup mounts out there, however be aware that they usually allow a bit more movement and you'll have some vibration to the camera which will make the video less excellent if you have a car that is less smooth. Also, of you choose to use something less secure you should have a tether of some sort to prevent the camera from becoming a projectile in a crash.
That’s interesting, I would have thought a roll bar mount would have more vibration..,,
No doubt!
I know the 'proper' perspective is objective, but I hate to watch videos that show the entire inside of the car because the camera is located either too close to the rear of the car or not zoomed at all. In those you can see everything, BUT the view through the windshield.
FWIW, we have a GoPro securely mounted via an IO Port mount, which is located on the horizontal bar of the main hoop.
FWIW, from the TMI dept - What apparently caused Michael Schumacher's current condition was his crash caused a helmet mounted GoPro to be driven through his ski helmet into his brain. I would presume a racing helmet has stronger impact resistance but knowing that was enough to not want me to mount extraneous stuff to mine.
Tons of factors to consider. But in general the suction cup mounts tend to be less rigid and more prone to vibrations. They also tend to have a longer arm on them, which exaggerates the shaking. The shorter you can keep the mounting arm, and the more rigid the whole setup the better the video will be in most cases.
