Topic: Mounting crotch/sub straps with seat sliders
Hey guys, been ripping my hair out for a while here, figured it's time to ask for help.
Can the crotch/sub belts on 6pt harnesses be bolted directly to the seat bottom? And how so?
The SFI guide (https://www.sfifoundation.com/wp-conten … -05-12.pdf), bottom half of page two, specifies that it can be. But I cannot figure out whether the belt is supposed to go through the seat bottom then attach to the seat, or whether it's supposed to go on top of the seat and under the driver (the "Driver is sitting on the Crotch belts" part), which does not seem right.
I have double-locking seat sliders, adjustable seat back brace (the IO Port one), 5/6pt compatible seat. and it all works well for adjusting to different height drivers. However, the crotch/submarine belts on my 6 point harness is bolted to the floor under the seat and cannot be adjusted without climbing under the seat and loosening the straps, which is incredibly annoying to do in the pits with your helmet on. The difference between the shorter fatter driver and the taller skinnier driver is such that sub belt adjustment is required with this fixed position. This would be greatly alleviated if the sub belt mounting could be moved with the seat.
Thanks!
