Topic: B13 Se-R electrical issue (Help!)
Ok, we're a new team with a "fresh" build 94 Sentra Se-R....
The battery is relocated to the trunk, i have added a kill switch and a keyless switch panel as well as added a tach.
My current issue is the car will not start unless the fuel pump relay is jumped and that tach doesn't work (it is spliced into the #2 wire on the ECU harness)
Attached is my (super fancy) wiring schematic for what I have done to the car to make that happen...
The ECU does not appear to be sending the signal to ground the fuel pump relay or to the tach.
I did cut the wrong blue/white wire in the ecu harness (the one that goes to the small ecu plug) when i first wired the tach, but that has been fixed and i haven't found a bad fuse.
I'm stuck at this point as I'm not sure why the ECU isn't giving the signal....so I come to you, SR20/Lemons experts for ideas where to look next... Thanks for reading my word fort and pointing out the blatantly obvious mistake I have made.
https://imgur.com/gAPq4kC
Hopefully these pics will link to Imgur.
