Topic: R56 mini trouble
So I have this car in my garage. It's a 2010 mini cooper base model stick. It had the apparently common sun roof leak into the interior problem resulting in first the fuel pump not working and later no communication to the ecu. Does anyone have any experience coming back from something like this? The interior is almost completely stripped right now and I have replaced the junction box and am replacing some corroded wiring and I hope that will fix it. I would love to decomputer ot but it seems like one of these semi keyless needs all the computers programmed to the vin type of pain in the a** cars. It has 56000 miles on it and I would love to daily it or throw cage in it for a future Lemons car or what ever.  Please help  or send help or beer or a haltech gift card and someone who is 100% better at wiring.
Re: R56 mini trouble
Mega/Microsquirt.
That guy
Have you got a CAN dongle? You'll need to work out what the ECU thinks is wrong.
I got a scanner and originally I had a fuel sender circuit b ot something like that so I convinced myself  that the 1/8th of a tank of gas I had parked the car with had evaporated and ruined the pump over the course of a couple of months. So I did a pump and filter. Then back to crank mo start but then no fault codes that I could read. So I ditched the bluetooth scanner and torque app for a better scanner that could send signals and not just read fault codes and reset. With that I had a junction box code which Is when i found the gallons of water that had been laying in the padding below the carpet. I saw some corrosion on some pins and replaced the junction box and tried to clean the wire connectors. Then i had a no communication to the ecu. We chopped out the offending connectors and are in the middle of replacing them. If that doesnt fix it... i will probably do a micro squirt but i am not sure what i am doing at that point. I get confused when i have more than 4 wires. I get electricity and all but when i start working on it i get instantly dumb.
