Topic: One piece/two piece racing seat?
Will a Kirkey 65 Series adjustable road race seat pass tech?  I didn't realize until I got it in the mail that it came in two pieces.  I read in the rules that only "one-piece purpose built racing seats" are allowed.
It's one piece when I put it together right?
Thank you!
Re: One piece/two piece racing seat?
I believe the ruling is that if it bolts together it's fine.  If it has a release lever and you can adjust it whenever, then no.
I think when King 1 calls it adjustable it refers to the back adjusting position in relation to the seat and in my experience King 1 is correct, that won't pass tech. But if after bolted together the whole seat will move forward or back then I have seen that slider adjustment pass tech if the proper adjuster is used. Better to use a double locking track slider that holds the seat really firm. See rules section 3.F. Loose / wobbly won't pass and a lot of teams fail on the back brace rule the first time through tech.
4 (edited by chaase 2020-03-27 02:54 PM)
Track sliders are fine. A seat with a back rest that the driver can adjust on the fly will not pass tech. If it all bolts together in one piece w/appropriate grade hardware, it probably should pass but Pagel makes that call.
We run a Kirkey 70-Series and asked Pagel about it specifically. Got the OK. Never hurts to ask TEO yourownself...
Ours looks like this:
https://content.speedwaymotors.com/ProductImages/91070151_L700_4ec56bec-8ea7-4884-9dd5-54d035aa0edb.jpg
It bolts together:
https://content.speedwaymotors.com/ProductImages/91070151_L850_7729abcc-7188-4b86-a513-582118315803.jpg
--bb
This very issue was discussed in this thread that ended with someone checking with Pagel who said the new Series 65 was okay.
https://forums.24hoursoflemons.com/view … p?id=36346
Thanks to all of you!
