Topic: Welding in the main hoop feet-this OK or do we totally suck?
Hi - we just finished fabricating the main hoop feet for our 1993 300ZX 2+2. Building the boxes went well, welded together on the inside and laid out the dimes. Sides are 3/16 steel and the top is 1/8 steel that came with the cage kit.
Installing in the car was waaaay harder. I've attached a link to a you tube vid of the work. It aint pretty, but good penetration. But we had gaps and welded over welds and also have some thin steel in the car laid over thicker steel that had some burn, so we had to weld over that. Circled that up so it was thick and solid. But ugly. You'll see some factory screw holes near the inner sides of the boxes, didn't weld up those. Should we?
Before we go further, installing the main hoop we want to see if this is good to go. Adult supervision requested! Please take a look at the vid and let us know your guidance.
Sent this to Lemon tech person also but want to get some input.
Video on Youtube here: March 14, 2020 https://www.youtube.com/watch?v=6cgUQ5dPfOM
March 14, 2020
300zx Lemons roll cage review
Thanks folks!
