Topic: Tech Inspection Pass/Fail Questions
Our first race is coming up next week at Road Atlanta. We really don't want to fail tech spec and have the following questions:
3.7.2.2 Battery and Other Electrical Terminals. All “hot” terminals on batteries, kill switches, and at other exposed points must be covered with insulating material.
1. Will the Liquid Rubber insulating material on our kill switch pass tech spec?
3.11.1 Engine Firewall. Gaps or holes in the engine firewall must be sealed up with metal plate or OE-type grommets. If you can see through it, we want it closed up.
2. We put some foam material to plug up a hole we needed for the kill switch wires to come in through the firewall. Will this pass tech spec?
