Topic: Viscous or Fixed fan Questions
My Cordoba does not run hot and I run a fixed fan that runs all the time with a stock type steel fan. It runs about 195- 200 degrees while racing and it has a 180 degree thermostat. . I have thought about running a viscous fan which has the potential to save 30HP if its not needed.
An electric fan might be the way ( If the fan is not needed most if the time) but that might also require some fabrication fitting in the shroud etc.. . Also the charging electrical system is all factory( fuse block, Alternator, volt reg etc. now)
The question are .....
a) do you think the motor needs a full time fixed fan to keep cool ?
b) Does the air flow past the radiator during a race keep the motor cool enough so that the fan isn't needed all the time.
c) Are flex fans any good
d) Does any body have any experience running a stock viscous fan?
