Topic: Running a vehicle with an engine notorious for overheating?
The resourceful LeMonster reaches for what he has in abundance to help keep things cool.
The 24 Hours of Lemons Forums → Bench Racing → Running a vehicle with an engine notorious for overheating?
Nioce...
but the Most interesting man in the WORLD does not approve...
I like the placement of the tecate can.
if you're really worried about it, lose the electric fan, bolt up a straight metal fan, and put back on the stock shroud. People underestimate the effectiveness of that little piece of plastic, and overestimate the usefulness of an electric fan zip tied to the middle of the radiator with no shroud. if that's not a 2.0l four banger in there (it's not, I know) that fan spells death.
You cannot beat the effectiveness of a well shrouded mechanical fan any day of the week. Electric ones suck.
Electric ones suck.
...or blow depending on which side of the radiator it's on.
The shroud is important as hell the perfect setup is a full shroud with w tight fit at the fan blades, extending to the centerline of the blades ...and think about how the under hood air escapes the engine compartment....the base of the windshield is a high pressure area and won't exhaust the air....took us 60 laps in the pits at Reno to solve that problem...if you're using an electric fan, make it pull, not push. and CLEAN the damn rad tubes...incredible how many rads I've seen where the fine dust and dirt clogs the fins...hose it out from behind....separating the auto trans cooler from the engine rad also helps a lot....and think about trapped air. Hondas are notorious for this. The bleed is there for a reason
Agreed. We removed ours, flushed the inside, then cleaned the fins with a pressure washer. I was surprised how much crap was in there. As for the auto trans...no 'race car' should have and auto trans...EVAR.
About the trapped air, if that is the case the car will overheat in two laps. Trapped air in a cooling system is the devil for sure.
I disagree on the electric fan vs. mechanical one though. Of course any fan needs a proper shroud to work as designed , but a modern electric fan flows a ton of CFM, and if you get one (or two) properly sized for the car they work just fine. We removed the mechanical fan from our E30 last year and used an electric one instead. The car never saw more than 220 degrees the whole race.
One more tip/trick is to run distilled water since we can't use additives like Water wetter. Distilled water has a higher boiling point due to the lack of impurities.
honestly i think that to keep these third gens cool you have to introduce more air to the rad. These cars have a nose that covers the entire frontage of the rad, and your not getting much help from the car moving through the air. My team noticed that in open air we would be around 220* but as soon as you were behind someone and they were blocking the airflow the needle would spike.... Im not saying you do this
but this solved our problem and the car does not move from 200*. after consideration had i have to do this again i would have used a 3" hole saw and not the sawzall but nid race what are you gonna do?
Chuck
Not trying to a smart a$$ Chuck, but you are aware that car (and most GM cars) is designed as a bottom feeder right? I run a Z-24 on track (often) and my 'radiator openings' are pretty much these tiny two ares beside the fog lights seen here:
The lower air dam (which I think I see in your pic) is designed as low pressure zone to 'suck' air up into/thru the radiator. GM uses this same design on the Corvette and most of it's other cars and it works just fine.
I'm not saying your idea won't work (obviously it did for you), I'm just saying the car's cooling system wasn't designed for air to be directly feed into the radiator via the bumper area openings.
i completely agree with you on airflow through the bottom design. My point is that for a car driven on the road not seeing more then say 3k rpm on a sustained basis that works fine. Now throw in the fact that you are pegged at or near the red line for 10 hours, with cars blocking that oh so precious clean cool air and you have a problem. which we found. your only choice is to introduce more air to help with overheating in the draft. i don't think that any amount of additional fans, or duct tape is going to help when you are in a vacuum situation behind another car at 60 mph
I would either cut the holes or make a huge sheet metal duct that was hanging down below the nose to introduce more air.
Chuck
cpmskinny wrote:Electric ones suck.
Touche
Hood and bumper alteration like so can be made for around $20 in sheet metal.
Which is kind of what we did with a return air vent from Home Depot Racing....
of course you can make it pretty like the guys above... i subscribe to the function before style mag tho...
Are you saying our aren't functional? For $18 we'll take whatever style/function we can get.
i think total we made the chicken coop for about 10 bucks. i never said it wasn't functional.. i just said it was pretty. lol
jimeditorial wrote:and CLEAN the damn rad tubes...incredible how many rads I've seen where the fine dust and dirt clogs the fins...hose it out from behind....separating the auto trans cooler from the engine rad also helps a lot....
Actually impurities raise the boiling point of any pure solvent.
I don't think distilled water would be distilled water for long after you pour it into an old cooling system full miscellaneous crud.
Your best bet for raising the boiling point is higher system pressure.
And just in case someone is wondering, de-ionized water is a really bad idea. It's corrosive.
That is funny considering we use it exclusively with isopropyl alchohol, here at work because of its properties. Granted we only use ot for washing parts before electrically bonding them or applying paint.
Thanks for the comments guys. I'm well aware that it needs a fan shroud, and it will have one. The mech fan vs. electric fan argument was solved for me with the motor that was in the car when I bought it - it had the Gen II LT1 motor, no provision to run a mechanical fan. It is not as small of a fan as you may think. The purpose of the post was just to show that beer cans have multiple uses...
Indeed - the packaging is almost as useful as what comes inside.
That they do... Should have thrown a Guiness can in there some where... just ot throw people off.
So uh... How has that LT1 worked our for you? Is your intake still like a opera singer sucking through a coffee straw?
LT1 blew up in the Reno race. Sold it and the Painless Wiring conversion harness that was in the car for $400, went with a traditional small block.
Theme Lemonade by Medico
