It's called "poor camber curve", very typical with McStrut suspension.
A proper sports car with a double wishbone suspension (or one of those other more complicated designs that it hurts my brain to think about) is designed such that the camber goes more negative as the suspension compresses so that you can run "conservative" static camber settings for good highway/street wear, but have the negative camber that you need to give you a flat contact patch under cornering. That would be a "good" camber curve... something like a Miata will gain about a degree for every inch of suspension travel (and they only have about 2.5" of travel).
The McStrut doesn't have a good camber curve (in general, it can't), and in non-performance applications (such as most FWD Lemons cars), the camber curve may actually go POSITIVE under compression, as yours does.
As someone mentioned, one way to deal with this is with roll stiffness. Big ol' front swaybar or stiffer springs/shocks. No roll = no camber change. That can be good. But, the big front bar comes with some negatives, such as inducing understeer. You can counter that by stiffening the rear even more than you did the front to get the balance of the car back. Then you won't have an understeer bias, and you'll have camber for a good contact patch... but the car will be super-stiff and unforgiving to drive. Decisions, decisions!
I like dsycks suggestion better. If you simply wanted more negative camber from slotting the top strut mounts, you'd slot inward... to get more caster (and thus more negative camber when the wheel is turned), you'd want to also slot rearward. I'd try slotting the upper mounts inward and rearward at about 45 degrees to get maximum negative AND maximum caster. Set it as far as it will go and see what you end up with and how it feels.
Don't forget to correct your toe after messing with the camber!
