Topic: Spirit of LeMons build update...
The final build video will not be released until we arrive at Carolina Motorsports Park on Friday morning, March 15th. We are going "media dark" as far as additional pics and videos between now and then, so any updates will be in written form only.
Why?
Well, partially because we want the final product to be revealed at the track. We've documented nearly the whole build in great detail, but a little mystery won't hurt. Also, most of what we are doing now would be much less interesting in video form. Nobody really wants to watch us weld small tabs and put small bolts from the fuselage to the chassis, or rivet plates to cover small floor-to-fuselage gaps, do they?
Here's what we've been up to:
The aluminum aircraft fuselage is now permanently located on the Toyota van chassis. The donor chassis itself has received a basic tune-up, consisting of plugs/wires/cap/rotor/fuel filter. Because it's an '87 with 176k miles that has been sitting for years, with rusty front brakes, and dried-out hoses, and we don't take chances with brake stuff on our cars, we installed new front brake pads/rotors/calipers/hoses. We still need to bleed them. We've finally heard the van run again for the first time since we cut it down to a minimal width and yanked out the dash harness, so there is hope yet. The tires we'll be racing on (a set of 185/60/14 all-seasons from a wrecked Miata, with about 30% tread remaining) are mounted and balanced, and now that we've cut the rear springs and loosened the front torsion bars, the whole contraption sits low and mean.
The cage is finished, save for the rear main hoop horizontal (shoulder harness) bar, which needs to wait until the driver's seat is mounted, in order for us to get the harness angle right. It's a 1.75x.120 DOM cage, and Jim Whitley of www.rollcagecomponents.com did a terrific job of bending it to the specs we had emailed him. It has a custom frontal crash protection structure that should protect drivers in even a worst-case scenario crash, designed by Evil Genius himself (it helps that he has already caged an identical Toyota van). The steering column and brake pedal/master/booster are mounted securely. My original plan was to use the twin Cessna steering yokes as dual control race steering wheels, to keep the magnificent Cessna instrument panel visually intact and untouched. However, for the sake of our own safety, and that of the other racers, we are keeping the Toyota column, and will have to eliminate a few of the stock Cessna radio controls in the lower portion of the panel.
Believe it or not, yanking the wings, hauling the plane home, gutting it, cutting out the floor, and cutting the donor van way down were the easy parts of this build! Now, we're into the really hard stuff. We have to polish the whole plane out, remount the first 20" of wing on each side with fabricated mounts, make finished-looking faces for the open wing ends, fashion rear fenders/dummy engine shrouds out of sheet aluminum and spun aluminum discs, and fabricate an entire tail section from scratch. It all has to really look the part, so it needs to be riveted together, polished out, and mounted securely enough to withstand the long tow on the open car trailer, and the stresses of racing CMP's fast full course. But, as a precaution for the other racers, we cannot reinforce the nose or tail sections whatsoever, so that the soft aluminum cones will become ample crush zones in the event of a serious collision.
Most of us have never done any sort of finished aluminum metalworking, so the next few weeks will be a steep learning curve. What we really need is a sheetmetal brake, an English wheel, and a planishing hammer, but those things are not in the budget. If there are any volunteers that have experience in this field, please show up Saturday! We also need to add the seat/harness/extinguisher/battery/cutoff switch, reattach the harness to the column, restore and reinstall the Cessna instrument panels, paint the interior floor with aluminum paint, replace the heater core hoses, add the fuel fill neck in a safe location, align the front wheels, and, oh, about a thousand other tasks. No worries, we four whole Saturdays left, right?
2 (edited by chrisbcritter 2013-02-10 05:48 PM)
Re: Spirit of LeMons build update...
Hi Speedy,
Don't sweat the panel beating and polishing - just stick a wire brush in a drill and "engine-turn" the panels to hide the lumps. It was done on the original Spirit for exactly the same reason. You'll end up with something like this:
http://i5.photobucket.com/albums/y164/ChrisBrame/Untitled-TrueColor-01_zpsf1943eef.jpg
Nice photoshop!
We're a third done polishing already, so we're gonna finish that up. Personally, I like polished aircraft. Plus, it should blind our competitors and make them all go four off and get put on the trailer, so we can totally dominate and win overall. big_smile
speechless.
"THE WONDERMENT CONSORTIUM"
Nothing's for certain, it could always go wrong. Come in when it's raining, go on out when it's gone.
IT LIVES!!!!!!!!!!!!!!!
I drove it today, under its own power. Not fast (4mph), and not far (150 feet), but dammit, it drove! Brakes were great. Stopping distance was inches. smile
This means we are way ahead of the curve on most (okay, ALL) of our previous ridiculous team IOE builds. Still lots to do...
HELP WANTED!!! Two build Saturdays left!!!
http://speedycop.com/spirit-of-lemons.html
If you need something done involving a sawzall or an angle grinder, I'll be happy to pitch in while I'm down there cutting your Miata in half.  ;-)
Saturday afternoon work for you?
you so crazy Jeff
Anytime. Bring an extension cord.
Last two build days, all day today and tomorrow. We leave tomorrow night.
All that remains is:
brake lights
wings capped
5 pt harness
extinguisher
kill switch and wiring
battery mount
finish building tail
cage padding
add coolant
finish fuel neck
mirrors
finish dash
possibly pick up Mechimike's two-car  trailer in B'more, and load spare Toyota van with tree-crushed roof as parts car
finish polishing
add fabric covers to dash and rear package tray
and probably a hundred other things I'm too tired to think of...
Once more into the breach, dear friends!
txt me if you want to meet up tonight to get The Deuce.  I'll need to hook up the trailer and swap vehicles to bring it to our pre-arranged meeting place.
Still don't know if this thing will fit on the trailer. I might be calling you later.
I'm around tonight.
Leaving now.
Time stamp note: 3:49 IN THE AM.
*facepalm*
Good luck.
Good luck buddy send me a text pic of this beauty
Rolling chicanelimo,95Lamdspeeder,LemonDemoCRX,Gimp Pimp Cadi,300zx Car show kaboom!! 90 Wagovan, mazda v8 dualley LEMONS LOGO TATTOO!
Aces 84 Cadi Eldo Briattz I O E WINNER finally!
Fabrication Required Transport 925-382-1058 I move Lemons and build cage
EX K Captain at The Ridge and now til it burns to ground
*facepalm*
Good luck.
So, business as usual then.  Good luck!
Bloomington, IN
Good Stuff!  Congrats!
Rally Baby 87 Audi 4KQ, Audi 90 Quattro Coupe, 1975 Mercedes R107, 87 E30s, E36s, the Whorenet, Rocco...
J. Phil: "Audis Never Win".  He might be right.But!, the K Dominates 2013 NJ and NH (not, but...).
Stafford 2011 podium, 2nd NJMP 2013, Summit Point 2012 "WV ASSimilation award"
NJMP 2012 Organizer's Choice - R107, 2013 Monticello IOE Whorenet ! Organizers, CMP fall 2013 w/NSF
18 (edited by Chaddd 2013-03-18 10:57 AM)
We needed some de-icer for that trip home!  Big chunks of snow flying off and pelting me while following home through the snow storm early morning.
YOLO BITCHES!
can't believe i just typed that!
21 (edited by autoxmike 2013-03-18 09:34 PM)
Speedy - Thanks for the once in a lifetime chance to race a Cessna without having a pilot license! That freaking plane is 110% awesome.
Also probably the only time I'll say "I was racing a fire truck in a Cessna when we both passed a K car on either side".
Mike
Hong Norrth
#39 TRON Gray/Orange MX-3, aka "Sumbich"
22 (edited by Chaddd 2013-03-19 05:55 AM)
CoCo Doug be crazy up in here!  Ain't got time for that!
Did anyone else giggle when hitting the kink in a plane at full tilt? As you go through the turn, it makes rushing wind noises like it's about to take off.
Brilliant! Speedy raised the bar once more, this time to 40K feet!
K Car Stalker
Did anyone else see Speedy made the cover of Yahoo today?
Congrats Jeff!
#411
'93 Acura Integra
25 (edited by psychoboy 2013-03-19 11:54 AM)
the commentary on Yahoo actually manages to make the Jalopnik commentary look better....
Team OK-Speed
Regularly losing in Class A
