Topic: repair help - leaky float
Help, need ideas. working on a friend's 78 rolls royce - it has v8 and dual side draft solex single barrel carbs. Its also a nightmare to work on with all the smog crap.
Anyway, one carb was flooding and venting out the spill tube, I tore it down and found the plastic hollow float filled with fuel.
I have tried many resources but cannot find a new float for this carb. What do y'all think? I thought I remembered you could get that float foam stuff, and I could cut it up maybe jb weld it to the float arm? SOB, I know this sound hokey, and it literally took me about 4 hours to get the carb off it was so covered in crap and blind nuts only a crow's foot would fit, etc - anyway, point being I REALLY don't want to open this up again so hokey pokey fixes not going to work. I have tried Ebay, rockauto, Pelican, etc and no one has this part.
Also, what about draining it and gluing the hole assuming I can find it? what glue would hold up to gasoline and ethanol?
Scott
Speed Racer Mach5 Mustang
Houston TX
