Topic: Question for cage for body on frame truck
I've searched through the threads here, and have read the cage rules and looked over the PDF many, many times. My team and I still want to understand something that we must be missing.
Is it required to weld the cage to the frame on a body on frame vehicle (in our case a truck)? If not, and we weld to the floorpan using the appropriate (or even oversized) spreader plates, can we then tie that location to the frame?
The frame on the truck sits inboard too far to cut through the floor and have a cage that sits around the driver instead on the driver. We'd like to use square tube to make outriggers from the frame to the location where we would like to place the cage, is that legal provided we are properly welded and on correctly sized spreader plates in the cab?
Can we remove the body mounts and make a solid connection through that location for the purpose of getting the cage to the frame?
I've written an e-mail to Jeff & John as I've seen instructed in other threads, but haven't heard back. We want to get our cage in before we register for our event.. but we are running out of time without these answers.
Thanks!
2014: Gingerman x 2 | 2015: Gingerman, Autobahn (24 Hours!) | 2016 Gingerman (April) | 2017 Gingerman (April)
