Topic: 2" helmet clearance clarification
Hello all. Before I trouble Evil Genius directly via email, I want to clarify the 2" helmeted driver rule. Cage is tacked in, but before we fully weld I want to ensure we're on the same page with the rule. Car is 1994 Lincoln Mark VIII. Using stock seat mounting locations with Corbeau seat and slider. Shortest driver is 5' 6", tallest is 6". Slider set so as not to allow the seat to extend more than 5" from the harness bar per rules. Main hoop provides plenty of clearance for the 2" rule. We are using left/right down tubes connected to each other at the windshield/roof line. At that point, the top of the connecting bar isn't 2" over the driver's helmet. If you draw a string from the top of the connector bar, over the driver to the top of the main hoop, and a string from the left downbar to the right downbar over the driver's head, we properly exceed the 2" of clearance over the driver's helmet. That's our understanding of the area contained by the cage. Other posts have said "imagine a box welded to the outside of the cage, and the helmet must be 2" from any of the box" which I think is the same idea. I just wanted to make sure this is the correct idea - string from bar top to bar top. If you drew a string from the top of the windshield connecting bar parallel to the rear of the car, you wouldn't get the 2" -- only if you draw it bar to bar (because the main hoop is higher than the windshield).
Is that clear enough of a question? Thanks to all for the help. Decision made which affects the above question - we are trying to use the stock seat location with a slider. We have also left the sunroof in, however this doesn't impact the issue which is the front connector - rear hoop left plenty of room even with the sunroof mechanicals.
Cage built having read each and every rule 100+ times, fabricated/bent by professional cage shop in Dayton, Ohio, being welded in by us. Adding dash bar and anti-bow bar as recommended. We are trying very hard to have hit every rule as written AND INTENDED and adding the extras for good measure!
