I can tell you first hand that the COOL SEAT idea does work.
We made a COOL SEAT which we used at summit point. We sewed 1/4 ID vinyl tubing straight to the back of the seat. We had about 5 parallel circuits on the seat which were fed by inlet and outlet manifolds we made from plumbing parts. Our pump was capable of 3 gal/min.
We had the same concern expressed by a few people on this thread; that heat would not move efficiently through our multi-layer suits. We figured our setup would just "take the edge off", and make it slightly more bearable. This was not the case at all. It worked tremendously well. It was over 100 F outside on Sunday, and sitting in that chair felt like someone pouring ice water down your back the entire time you were out on the track. At one point one of our drivers actually had to turn it off... it was too cold. It really made the driving enjoyable, none of us ever complained about the heat while driving.
I think the key is volume flow rate. A cool suit can't be bulky since it has to fit inside your racing suit. The inlet and outlet fittings have to be small and flexible, so you are limited in terms of flow rate. A cool seat on the other hand can be any size you want since everything is permanently mounted to the car. Our main inlet and outlet hoses were 3/4 inch ID. So you can make up for the poor heat transfer of a multi-layer suit by using a massive water flow rate.
Our cooler was about 10 gallons which we kept about half full. We figured we would have to scoop out the water every driver change, and then add more ice, but this turned out different as well. The water level just kept going down. I guess it was leaking out around the lid. All we had to do is dump in about 5 lbs of ice every hour. We never had to drain or scoop anything out.
Lessons learned: Throw a piece of foam on top of the ice to keep the sloshing down. Don't put bags of ice in. The ice melts, and the plastic bag clogs up the pump.
Thanks to Bernie for building our cool seat, it was a life saver!
Kris
Greenhousegassholes
White e30, number 911
Kris
Monkey F-ing a Football E30. Car 911.
