Topic: Random daydreaming: cheapest Turbo/SC engines for ill advised swaps...
Hi:
While I'm pretty much married to a 5.0L engine for our Lemons car for now, I was thinking this morning about what engines would make a project car interesting to drive (vs. appeal to the judges sense of audacity) AND somewhat affordable (in terms of replacement spares). If you folks HAD to swap in a turbo or supercharged engine (vs ghettocharging what your car already came with) for a Lemons or budget build project, what would you use? I'm also assuming that you are considering a more involved swap than swapping in the turbo/SC engine from a fancier version of your project car (example: SuperCoupe engine swap => Tbird chassis or MR2 turbo => MR2 chassis)
If you did swap a turbo engine into your Lemons car, why did you pick that particular combination?
Any thoughts here on these engines? I'm assuming of course that for a project car you'd grab the engine+ECU+harness and maybe the transmission if there was some sort of electronic control or it didn't readily mate with your chassis's transmission. I also approaching this daydream thinking this would be swapped into a Front engined, RWD vehicle.
Q: What else would you consider?
My Top Four
Volvo 4cyl Turbo: plentiful in junkyards. Can be mounted longitudinally so RWD swaps should be more easily doable (right?). Not sure about parts costs
Ford 3.8L SC Mustang/Tbird: Donor cars can still be had for cheap.
GM 3800 SC from Buicks/Olds/Grannies: Donor cars can still be had for cheap. Not sure how easy it would be to swap in b/c of it's transverse mounting. Any manual options?
Ford 2.3T : donor cars can still be had but from my experience selling off an old Tbird 2.3T ECU, I'm willing to be that these are drying up b/c of the cult following. What say you?
Worth Considering
Saab 2.0T: tons in junkyards. A friend had one and said that the build quality on the direct ignition cassettes made it an oft replaced part. Are parts cheap?
VW 1.8T/2.0T: they make a lot of power but I'm sure parts are expensive (based on my experience owning a Audi 2.7T
Engines that are Probably Too Expensive (for Lemons at least)
Nissan SR20DET: sure, you can get them from Japan but that supply has to be dwindling now as those case were pulled from the streets. Also drift monkeys probably push up the demand.
Nissan RB26DETT: All blocks are imported. No junkyard will have them. I've read that some parts can be crossed with domestic US Nissans but parts costs HAVE to be higher. Also, drift monkeys.
Mazda 13B swap: Rotaries may be lightweight but I'm not sure their lack of torque and high parts costs make this a viable swap into a random project for anything but the most serious rotary faan.
Audi 2.7T: uhm. no.
