Re: A DECADE OF DISAPPOINTMENT
It's roughly like CMP but damper and moister overall. Much fewer fire ants. HQ gets to be inside a building with walls which is a plus. The Judges are in basically an echoey metal phone booth which is less of a plus. Paddock lane control is stricter since there's only one flow that works the way it's laid out. Go the wrong way too much and you'll be having a bad time soon.
The ground is also less Brick hard like a lot of CMP is. Easier to stick things in, but easier to get things stuck in.
Weather will be in the range of 0-100 degrees F, 20 to 100% humidity, with the potential for Rain, Snow, Overcast and/or Sun at seemingly even odds.
