Pegasus brake hose for FTW. Brakes and safety, good places to not save any money. That is unless you don't like your teammates.
https://www.pegasusautoracing.com/produ … oduct=3621
If you have ventilated rotors you can remove the backing plate and fabricate you own that closes off the entire inner diameter of the rotor, weld a 2.5" or 3" tube to that and duct it to the front. That way you pressurize the rotors own air flow when driving. This is a lot more effective than just aiming a duct at one side of the rotor.
We drive the wheels off the Alfa and this is the only cooling mod that made a big difference in rotor temps and kept our Carbotechs from melting down.
I have some photos if you are interested
Greg
1987 Alfa Milano (Bellissima since 2008), Racing since 2008 Stafford Springs, 2nd overall 2011 NJMP, 4th at NHMS 2011, 2nd at Summit 2011, Into the wall hard at Stafford Springs 2011, 2nd at Monticello 2013, 3rd at NHMS 2013, 2nd at NHMS 2016. 2nd at NJMP 2018
25,000 racing miles in 32 races in 10 years. Yes its the same motor. Tell me again how Alfas suck? Update: Big moneyshift = new motor
