My suggestion is to go with the flat panel for simplicity's sake.
- Also, while you are cutting/painting the metal panel, just go ahead and make a spare. THis way, if you find yourself wanting to remove gauges, you have a replacement panel already pre-made.
- My gauge panel has evolved over the past few years as my love for gauges grew (oh, I need this) and most recently I've actually gone in the other direction to try and simplify things (too many gauges means the most important ones tend to be ignored).
- I originally started with a modified dash panel (as you initially planned) and then abandoned it as I found myself wanting more gauges.
- My most important gauges are already mounted in front of the driver (RPM, shift light, fuel level, and knock sensor).
- For my gauge panel, I've found the most useful ones to be: coolant temp and oil temp. Coolant pressure is not necessary (light is sufficient) and VOLT gauges are useful to diagnose issues but can be ignored while driving. I also found the most accurate temp displays that can be read at a glance were the dual displays from AuberINS (a guy recommeneded these to me and I've found them to be more useful that my autometer gauges). Also, my car's ECU is too stupid to query the car for this info.
- In mounting your tablet, be aware that you may need to make a shroud b/c of glare. Factor this into your design.
Frito Making Tbird from 2018 Sears Pointless Engine Heat BBQ -
http://goo.gl/csaet4
