Thanks guys, it's been a lot of work but seeing the feedback here has been fantastic.
I sat down and made a tally of the todo list as it currently stands. This is more for me than anyone else but I figured some would like to see it so here it is:
1) throttle bodies
a. order 5th throttle body
b. get larger injectors (current injectors are 235cc, should be good for about 200HP but I’d like to have more headroom)
c. make fuel line feed connectors
d. mount on motor (flanges should be back from waterjet in a few days)
e. get filters (buy some cheap foamies or something)
2) exhaust
a. flanges should arrive from waterjet in a few days.
b. Exhaust pipe is already here, weld it up after the intakes are in place
c. Route to avoid everything, pray that it’s quiet enough with strait pipes (this is probably seriously wishfull thinking)
d. Paint with high temp paint so it doesn’t turn to rusty crap in a second flat.
3) Oil reservoir
a. Nothing done on this yet. I need to make an approximately 5gal oil reservoir for the frunk.
b. Place fins on it or something to cool the oil
4) Find a fan to move air across the motor.
a. LOTS OF AIR!
b. This needs to be planned SOON!
5) Shift linkage
a. Order push/pull cables
b. Make brackets
6) Megasquirt
a. Crank trigger wheel
b. Cam/crank sensor mount (sensor already bought)
c. Wiring harness (a whole lot of it)
d. The computer is already ordered and should be here within a week.
e. Figure out how to tune megasquirt ?
7) Transfer case
a. Make a flange for the angry hamster box to the small sprocket
b. Make a flange for the prop-flange to large sprocket
c. Wait for new case back half to come from CNC shop.
d. Assemble everything
8) Clutch
a. get custom clutch disk to fit 93 spline on ’08 wrx flywheel/pressure plate.
9) Safety (last 15days)
a. Cage
b. Seat
c. Brake light
d. Extinguisher
Over the weeknights this week I hope to achieve the following:
1) Get all the cam/crank wheels/sensors worked out and finished. (this may not be possible since the crank wheel may not arrive till very late into the week)
2) mount throttle bodies & all throttle linkage.
3) make exhaust pipes.
Yeah, I think that’s it for now.
