On the lights - yeah - if you bring ultra Dazzler LED's prepare to be given no quarter on passing. THOSE REALLY SUCK for OTHER DRIVERS. (yeah - when you come up on someone, the driver in front cannot SEE ANYTHING and will hence become pretty erratic)
~Also, HID "Conversions" (True HID) DO NOT WORK. the HID bulb glow is not the same geometry as the original Filament. This means that the carefully crafted and designed reflector and lens setup in your OEM lamp case are not set up for the change, and all you get is diffuse GLAREY light. This would be great to aim backwards at someone with LED's - but not much else.
Other than that - the rules as above are pretty true - Start with the OEM's, add higher-wattage bulbs if you can (some bulb types can source 80/100w vs the stock 55/60w) then add driving lights (not spots) aimed cross-ways to illuminate corners.
I also recommend adding/keeping your side-marker lights (or adding theme lights) so that if you are sideways someone has a better chance of seeing you w/o tee-boning you.
On-topic - looks like the Scrubbing Bubble VW will be there.
Linda, I'll gladly watch a T&T, and probably pay for one or two sessions,
but I think I'd rather have some sort of "passenger-car track-acquaintance-no-passing-high-speed-tour" group for a handful of people that haven't been there added in - say $25/car later in the day - maybe 45 minutes? Basically a double-yellow only session for newbies... Anyone have thoughts on this?
