Please do not overlook the fact that the promoter/sanctioning body sets the flag standards for the event. The changes may not have been relayed to the workers.
In 2009, some of the flag group at Nelson have worked with the flag standards including, ALMS(modified FIA), IRL, SCCA, NASA, WERA, AMA, SVRA and NASCAR.
All are a bit different.
The best solution is to use a Lemons modified flag standard for road courses.
The single yellow all around is from ovals. The concept that a driver cannot understand the difference between a single and double yellow has led to NASCAR using a single yellow for course yellow and blue for a local yellow?
Calls to control regarding contact, cars off, etc are supposed to be Numbers ,Colors and car location. We DO NOT call anyone by name. Although we may know the driver they are to be treated as if we do not. I think if they knew it was me they would have found something.....
The most important thing is numbers which can be read. We attempt to provide eyes and ears for race control without passing judgement. Just the facts no opinion. Its not a perfect system but works pretty well. There are times when calls get delayed to check numbers the next time around in an effort to make sure you have the correct cars.
A follow up suggestion for Lemons flags, would be the following,
Yellow- local yellow-NO PASSING until past the next station ( as you may not know that there could be two cars off). FIA requires a following green at the next clear station.
Double Yellow- full course yellow NO PASSING ANYWHERE.
Blue Flag - this is a tough one, CHECK YOUR MIRRORS ( nothing more). I appreciated the blue flags I saw BECAUSE we were not so fast. Many cars can close very quickly. it does not mean move over, slow down or anything else. It means you have cause to check your mirrors.
White Flag- SLOW MOVING VEHICLE, Probably a wrecker or safety truck.( One does not need to follow the wrecker, go around in control).
Black- Penalty Box
Red- Come to a stop in control on the right side of the track and await instructions.
The corner flag sets are equipped to handle all of these.
We normally use Stationary light for local yellow and flashing for course. At Lemons the flashing was for incident on or close to course(as described at the meeting)
If everyone understand this going in it does make it easier.
Its tough for me to be critical of the flaggers but then I am one.
They are not perfect and they are VOLUNTEERS. We cannot cut their pay.
I can say with high level of certainty that the corner workers saw cars in places on track that they never have before. Like 3 wide in Oak Tree, 4 wide exiting 13, 3 wide in the carosel.
I have worked every corner at Nelson over 15 years and never have seen some of the situations I was driving in............................
In terms of safety, did anyone notice how many cars were in tires and continued?
All in all, We had a BLAST and hope to be favored with a Lemons race at Nelson next year.
That's my $.02
