E-Speed wrote:I bet that you argued your position that nothing is going to go wrong when your Mama told you not to play with matches. To openly tell everyone that you plan on making them an unwitting participant in your experiment that a Chinese tie rod will withstand the loads of a ball joint that it was not designed to handle is insane.
here's a thought...try reading and comprehending what i post BEFORE you decide what your position shall be and start your railing.
i've got over 6 months to beat the ever loving fuck out of this thing before any of the LeMonheads are exposed to it. perhaps you missed that part where i mentioned the autocrossing this car will see monthly between now and then. single car on the track, every bit as punishing as Lemons can be, and it won't be given a break. if something does fail...it'll be me or another member of my team that is in the car when it happens.
lets assume for a moment that the ball joint fails, what will actually happen? the wheel assembly will tuck into the wheel well, the tire will probably suffer some injury, and the whole car will come to a rapid stop, dragging a front tire.
i don't see a whole lot of room for death, dismemberment, or general havokry in that. exciting for a minute or two? sure. instant death? hardly.
If your Chinese tie rod/ball joint experiment fails, who will your victim be in the hearst that your experiment just killed? And you think it will be funny to video the hearst?
no, i think it's funny that you equate a failing ball joint to instant death.
....or sad, i'm not sure which.
oh, and since it would likely me be driving, all by myself, i guess that guy in the 'hearst' will be me. i'll make sure someone gets the video to you so you can be the first to say 'i told him so!!!"
(man, i wish there was a sarcasm font)
Please do everyone a favor and stay home. Don't tempt Lemons perfect 0 incident related fatality score, the one heart attack is more than ten million times enough. Regardless of what you may think, Lemons racing is dangerous enough with out somebody like you. Don't screw around with safety. This is not a place to save a buck.
And to answer a prior question that you ask, I don't know how many ball joints have failed in Lemons. That is not the problem at hand.
that is exactly the problem at hand. you are concerned about my lower ball joint failing and killing everyone in attendance, but you have no knowledge of the number of other people's lower ball joints failing, or the casualties caused by such. oh, wait....nobody has yet died due to a lower ball joint failure.
so...why will my lower ball joint failure kill someone when nobody else's has?
i can certainly understand your concern of failure...i share similar concerns. the difference is, you are concerned about something you seem to have no knowledge or experience with and that lack of knowledge is contributing to this farcical 'you're gonna kill someone' rhetoric, and i am concerned about the realities of the actual situation based on the experience i've had with these parts and suspensions in general.
0 is the number of Chinese tie rod end operating as a ball joint failures because there has been 0 fools attempt to experiment with 100 plus participants lives.
do you know that? you don't even know how many lower ball joint failures have happened during the series (for the record, neither do i...but i'll assume there's been at least one, and it didn't kill anybody). surely, you haven't done tech inspection on all those cars....
again with the rhetorical hyperbole that you've shown little to no basis for.
if i hadn't mentioned they were the Chinese ends, and said they were the German ones, would that satisfy your concerns? are you just bigoted against China's spotty production records?
i'll ask again:
although you've expressed tons of fear, you haven't explained how you rationalize any of it.
you are sure this will break (tho you've not decided how or why) and you are sure this breakage will injure or kill someone (tho you've not explained the mechanism that would cause this to happen).
so...please, give me some rational explanation for your hyperbolic concerns. you have all this fear, i have to assume you have something backing it up. (did a chinese tie-rod kill a favorite uncle or something?)
explain how you think this part will fail; will the threaded stub shear? will the taper break off the ball? will the ball casing split? will the FSM decide i have divided by zero and form a black hole, sucking the track and all the competitors into it?
explain how the failure will result in anything beyond a fubar'd tire/wheel and a visit with a tow-truck operator; will the kunckle assembly come off the strut, brake line, and steering rack and fly into the spectators? will the wheel cramming itself into the wheel well cause the steering and braking systems to stop responding, resulting in the car careening out of control like a runaway audi? is the inside of whatever you think will fail (the ball, the taper, or the rod) actually full of vaporous uranium, which will give everyone in a 60 mile radius radiation poisoning?
suggesting that a broken lower ball joint will kill anyone is right up there with suggesting the illuminati are creating chem-trails for mind control purposes. sure....it might be happening, but it's damned hard to prove, and there's no real evidence to suggest it.
express all the concerns you like, but temper them with reality. otherwise you come off sounding like a crackpot who just wants something to rail about.
Team OK-Speed
Regularly losing in Class A
