I bought the biggest 110 Lincoln Welder on the market back when i was 19...that was over 15 years ago (sidebar: now I feel old). I have used that welder for everything. When I first bought it, it was flux core only, and I even used it for some (very bad) body work. It was fine, you just have to adjust to the extra slag and not as pretty welds. About 7 or 8 years I finally plunked down for the bottle, and love it. I have welded .25 material with full penetration, it just takes extra long, or you have to be able to access both sides. I even have used it to "cut" material up to 3/8 diameter (basically heat it up with the feed speed way down).
Occassionally I bump up against the 20% duty cycle, and have to let it cool down a bit. But it's a minor inconvenience, not really a seriuos annoyance.
I have owned and used this welder for 15 years. I have carted it all the way across the country and welded stuff on the sand at Burning Man with it. I have taken it to ~10 Lemons/ Chump races and used it at every one. It gets tossed in my truck and taken with me everywhere- sometimes I swap back in the flux core if I don't want to bother transporting the bottle. After 15 years, countless full spools of wire, many bottles of gas, and more pairs of welding gloves than I can count, I would totally make that purchase again in a heartbeat. The only things I have replaced on the welder were:
- The grounding clamp, which eventually broke after about 14 years. I bought a heavier-duty one from Tractor Supply for $15.
- After taking it to Burning Man in 2008, the playa sand caked the inside of the wire feed cable and caused it to rust, so I replaced that.
- Pretty sure I replaced the wire feed wheels at one point, maybe 5 years back. They were cheap.
I've broken a few welding helmets and more than one gas gauge, too.
A buddy of mine found a barely used setup at a garage sale for $75- same as mine, without the gas. That was the steal of the year. I paid ~400 for my setup, and the equivalent unit is now like 600. If you can find a good used unit, that's the way I'd go. I've totally abused mine, it shows, and it still works great. So if you find a used one that looks cosmetically good, chances are it'll be a good purchase, even if you have to replace a wire feed spool or a cable or something.
