Topic: The Brakes Thread...
There started to crop up a heated debate on the subject of brakes/braking systems on our crap cans. Troy in particular is an advocate of going full-on race pads, which, in truth, is a pretty good Idea. In the ChumpCar series, there was "brakes on fire" scenario that some people are speaking of critically. Should this mean more vigorous TECH inspections? should it mean a minimum pad rating? Well, that's what this thread will be all about. Below is my personal experience from 5 Lemons races since 07. To be clear, I'm not pushing to have an uprated minimum braking system, but I am promoting the self-policing philosophy of making sure your new 74 pinto has a fresh quart of fluid and at least rubber lines that aren't dry rotted.
Traditionally, at these events, we've run stock pads. did it with a 93bimmer at flatrock, did it with a P71 @ CMP. the bimmer went all 24, the P71's fronts were wafer thin at the end of day one. dash to the parts store, got some Severe Duty pads, all was good. never never never had a problem with losing braking altogether.
Nelson rolls around, Widely accepted as one of the most gentle tracks on brakes in the schedule, new car, stock pads, first driver cooks them in 40 minutes. not crack, not wear them away, Cooked them. Now, I've seen countless teams recalling the aftermath of NL, talking about brakes and tire wear, and many report that they were running the CHEAPEST PADS ON EARTH(or at least that they could find) and almost all of them were saying they went the whole weekend on a single set. So... I'm thinking there may be an issue with his driving style at this point.
I guess the bottom line is, that, even with a big, heavy car, cheap-ass pads, and over-aggressive driving, none of these were fires, wrecks, etc. a Basic "Braking system state/function" check should be mandatory. I'm NOT saying mandate a specific pad/rotor/system. I'm just thinking it's not hard to check the Master Cylinder and lines for leaks/cracks/excessive wear.
Well, I didn't mean to start this in for lobbying for new rules or anything. I would just think it's common knowledge to make sure your safety equipment is in good, working condition before you put it on the trailer.
To review, I'm not saying you have to spend $600 on brakes to compete. I'm just saying that having their specific state & function verified is a good, sound idea.
