the 1950s equipment (i'm guessing it's original to the house)
the current setup of the wall, and my grand (poorly drawn) plans:
the door on the right opens into a 3/4 bath (sink, toilet, shower stall), the door on the left opens out of a closet. the area behind the electrical panel is a linen cabinet for the bath
this collection of rooms/hallway is in the upper right of this poorly photographed floorplan:
a detail shot of that area. the black/dotted lines are the existing walls. the red is a washer/dryer stack and my first plans (blowing the door frame area out entirely and basically making a dead end hallway out of the area, no wallboard frame on the existing hallway):
right this very moment, the wall section between the door openings (not the frames or the moldings, the actual openings) is right at 30", so, by some interpretations, we are code compliant (tho one guy in town started talking about 33" wide for some reason). my plan is to widen the opening going into the closet from a 24" door frame to a 34" drywall opening, and the closet behind it from 30" wide to 40" wide. this will narrow the panelboard's wallspace to only 20". If code demands 30" of actual wallspace, i'm boned, but if code considers doors and other openings in the wall plane to be equivalent to wallspace, then i'm still good.
....and that's where the crux of the question lies.
and...just to complicate it further, i need somewhere to store my detergents and fabric softeners. I would like to access the existing cabinetry that's in the bathroom behind the panelboard thru a new pair of cabinet doors in the hallway, under the panel box. construction-wise, the panelboard and the cabinet access would live in the same 16" chase, all of the electrical runs would run through the top of the panelboard. the light switch would go across the hall, and the receptacle would go away. the picture doesn't reflect it, but i found that the panel board and the cabinet would be the same basic width, because there is only so much room to cram 14.25" of panel board, and 2.5" of bathroom door molding in 20" of properly framed wall.
if i can't hang a cabinet door in the chase below the panelboard (due to the non-electrical items part of the code), i'll end up having to make the deadend hall and store the stuff next to the stack. while possibly more functional, it doesn't really fit the style of the house.
so....clear as mud?
Team OK-Speed
Regularly losing in Class A
