Topic: active aero project
I've had this idea kicking around my head for almost a year now, and I finally started to jump in last night. I want to build an actively controlled split rear wing, much like the AeroMotions S2.
http://www.youtube.com/watch?v=p7l70Q6P-vU
First things first, I'm not doing this because I think i'm reinventing the wheel and creating something new. I'm doing this because I think it will be a fun project to teach me basic programming and controls. I also expect almost zero performance gains on the car, but it should be entertaining to watch operate.
Basic idea i'm starting with. System is controlled by an Arduino Uno. I'll be using throttle position, brake pressure, and steering position as my inputs. Outputs are the two motors driving the rear wing pieces. Basic operating principle is the following. At WOT with the steering straight, the wing lays down flat to reduce drag. Under braking with the steering straight the wing stands up to act as an aero brake. Under cornering the inside half is raised to add downforce to the inside of the car.
I'm literally just starting. Bought the Arduino last night, and so far i've managed to get it to read the TPS, and convert to a percentage. I also hooked up a basic push button switch to simulate the brake switch so that I can start trying to figure out the logic for setting wing angle with more than one input. Tonight i'm trying to get it reading a potentiometer to simulate steering angle. The coding for all of this is where i'm going to get the most hung up, but that's the point, I want to learn how to do it.
Abandoned E36 Build
