Topic: 465 cu.in, 2 cylinder, unwise swap?
Maybe the 3 cylinder Saab guys would be willing to drop down to 2 when they fix/replace their motor.
465 cu.in, 2 cylinder, firing order is 1-2, 3.9:1 compression ratio, revs to 800 rpm, will probably run on any fuel but takes 52 quarts of coolant. I don't see the power/torque specs. Probably a lot more torque than power.
Link: http://www.tractordata.com/farm-tractor … ngine.html
24 Hours of Lemons on Vimeo, Team Tinyvette on Facebook, Team Tinyvette
