Topic: Advance Auto Buys Carquest. Discuss.
http://www.reuters.com/article/2013/10/ … CG20131016
This leaves somewhat of a dilemma. I frequent both my Advance and my Carquest. Advance is my go-to for fluids, mainstream parts, and other various "easy to find" components. Carquest is my savior for "I need something to work... now." My Carquest has been open since 1896 (not a typo). I once took my '72 Mini Truck for a quick spin around the block before taking it to Eurofest the next day. And the clutch went out. The seal for the slave cylinder went kaput. This was at 5:28. I went to Carquest and, after spending two hours searching (they close at 6:00), he found that the seal from an Isuzu Trooper rear brake is the same OD and ID. It worked. Amazing. So here's the problem... are they going to incorporate? Combine? I need both of my stores!
I'm just glad Autozone didn't buy them. Then I'd be in a real conundrum. If I was stranded and had to walk 50 miles to the nearest town, and Autozone was the only option, I might go there. That of course assumes that whatever left me stranded could be solved with an air freshener, some LED underglow, and a stick on "chrome" porthole.
So... how does this effect your life? Are you trembling with fear? Jumping for joy? Writhing in indifference?
Fall 2013 CMP I.O.E.
Shine Country Classic 2014 and Southern Discomfort: Showed Up; Didn't Blowed Up
Humidi TT: DOMINATION. Barber 2015: "Least Southern Pickup Truck"
