Re: My first Lemons build - What am I screwing up?
The best parts store pads are hit and miss. You'll waste a lot of time replacing pads and rotors (and possibly calipers) if you get it wrong.
Don't cheap out on the pads. a set of XP8 for the front are less than 150.00, and you'll get at least 2 races out of them. We get over a season out of our RP2 pads. $200 well spent.
I'd agree.
XP8s on a 1800# Honda lasted for ever, like +4 races. didn't wear out rotors and awesome brakes. BUT BED THEM CORRECTLY.
XP8 on the front of the 2700# Valiant have also lasted like 6 races.
But ~$200-225 per Axle. So $400
So lets do some math. Regular Duralast pads from Autozone are $25 with tax. So that says 8-9 pad sets are equal to one set of XP8s.
the fiat is about the weight of the Honda, so at least 4 races. If you kill 2 sets of cheap pads per race its a draw.
But you said you had some EBC pads. Use those first, see if you get any brake fade, then you can always send the used pads as cores to Mike Jr at Carbotech. (save your old brake pads to send in, its unlikely they will have brake pad cores).
