Re: My first Lemons build - What am I screwing up?
racinrob wrote:Also, wire the starter button so that it can be used with the ignition not turned on.
NO!
This is NOT allowed per Rule 3.G.1 (see bold text)
3.G.1 Master Electrical Kill Switch. All cars must have a racing-type master electrical kill switch easily turned both off and on by the belted-in driver. The control for this switch should be red; the OFF position should be clearly indicated; the switch should be easily accessible from outside the car; and the switch should be clearly marked by a three-inch or larger lightning-bolt symbol. All electricity must be interrupted by the kill switch (if you don't do that, the engine may still run off the alternator even after the battery circuit is disconnected). Don't put the switch where it's likely to be hit by another car in traffic or crushed in an accident.
Everything in your car should stop working when the kill switch is OFF (unless its your cell phone or a gopro camera with its own internal battery). The car battery +12V should only be present at the battery +12v terminal and at the input terminal to the kill switch. Wiring the starter to crank an OFF engine is not allowed. This is to 1. make sure the engine stops when the kill switch is turned off, and 2. to make sure there are no live wires in the Car/engine bay when the kill switch is turned off (live wires, like sparking live wires that ignite gas or oil).
Or how about your car crashes, the driver turns off the engine, leaves it in gear, gets out, but steps on/knees the starter switch, which then jams closed. Your car is now running on the starter down the track with no driver.
Nope, not allowed.
RacinRob, you need to re-wire?
I think what he meant was bypass the stock ignition switch with a new one, that way you can still start the car when the stock wiring harness heats up and craps out. The master kill switch would still kill all power and prevent it from starting.
