Topic: Should be in Lemons Tech?
But the Dangerous Banned Tech trophy was discontinued.
http://www.themoscowtimes.com/news/news … 50503.html
Unionized Physicist
Tetanus Racing
1986 Porsche 944, #986
The 24 Hours of Lemons Forums → Drivers Lounge → Should be in Lemons Tech?
Yep, that's the city where I was born.
You sure you want to admit that?
You could look at that two ways.
If you're stranded in some God forsaken place with a blown out tire then you are being resourceful but if you doing this when you are in the middle of a major city because your to cheap to get a new tire then your an idiot!
What's the wear rating on that log?
well it does have 4 wheels, just one is mounted to the back.
Looks like a 6S (6" spruce) rating which is not as good as 6 DF/H (6" Douglas Fir/ Hemlock) so if you want that in a spruce you have to go up to the 7S. All ratings are for #2 or better with less than 18% moisture.
PS: Anyone that gets that joke is spending way to much time trying under-size a joist with proper justification.
Oh, I've not under-sized a joist before, but I spec temperature, flow, pressure, and pipe diameter all the time, and that's some funny stuff right there. I'm going to giggle the rest of the day about that reply.
Paulie Lugnuts wrote:What's the wear rating on that log?
Been there.
OnkelUdo wrote:PS: Anyone that gets that joke is spending way to much time trying under-size a joist with proper justification.
Don't forget viscosity based turbulence and the pipe thinning that can occur. I sit behind you in the office. I nod my head a lot like I understand.
