Topic: Parts swapping verses diagnostics
I run into this quandry every race and ever week or so on a car forum I belong to. With our (usually) less than modern cars there is a good chance we have a crude diagnostics systems for ignition and fuel injection. Odds are they CAN point you in the right direction but it often cost significant time and unless you know THAT car well enough to know what THAT code actually means can lead you down a rabbit hole.
In my case, I can tell you from the ODBI flash codes on an LH2.4/EZK system on a Volvo what is really wrong when it says "mixture too lean or too rich" in three guesses. On a GM ODB1.5 Buick 3800...It takes 10 minutes just to get the stupid computer to sync and pull codes and it does not do stored codes.
So, if you know the car a little and know suck-squeeze-bang-blow is how an engine works, how do yo handle problems at the the track...and conversely when wrenching in the comfort of your garage?
I will give two examples:
We are missing at high speed, when hot with the 3800 Series I in race conditions. Wires and plugs swapped to no avail. Engineer teammate plugs in the computer while I have the rest of the team grabbing coil packs from the spare motor. In the end it APPEARS to have been a bad coil pack but we were also overheating without knowing it so we were knocking so the timing was being retarded. I threw parts at it and got it back on the track but did not fix it...maybe.
Volvo 1990's 240 will not idle until warmed up. Hunts up and down and stalls if put into gear until the idle stabilizes after about 5 minutes of idling. It is taking longer and longer to stabilize idle and now occasionally idles erratically after warm. Owner throws a NEW IAC (why not just clean it), O2 sensor and cleans the throttle body. Two questions got me to a diagnostic track "Does the TPS click on throttle open", "Did you adjust or disturb the TPS when you cleaned the throttle body". Since he did not understand either question, I knew he was a parts swapper. A five minute diagnostic procedure had him idling perfectly after he loosened two bolts and twisted a little left.
So...at the track, I throw parts at it until it works until the race day ends. Online and in my garage, I diagnose, test and often repair. Where do you fall in the spectrum.
