Topic: Halo to main hoop junction
Our car, like many, is somewhat tight on interior space. We mounted our seat to the floor, so we're golden in the vertical direction, but we're always going to be somewhat tight in the lateral direction (ie between helmet and top of the door/window).
We would like to run the halo tightly along the a-pillar/roof edge while staying as close to the roof as possible. This means that the halo won't intersect the main hoop without an additional bend at the end of the halo.
Two questions:
1 - is it ok to have some small bends at the end of he halo to facilitate it being closer to the roof?
2 - can we remove the factory roof rail to get the tube out closer to the edge of the car? We are running a 1.75" x 0.125" tube in a car with a factory curb weight around 2600 lbs if that matters
Here's a picture of what I'm talking about:
Here's a picture from another 3rd gen prelude team's build. Note the small bend at the end of the halo and the material removed from the factory structure.
