1 (edited by bam2002 2010-01-29 08:22 PM)
Topic: Update on the Yertle team VW and our new Tow vehicle
The cage is started, about 60% done. We still need to figure out a way to protect the engine.
http://www.facebook.com/?ref=home#/prof … 0548740854
http://i206.photobucket.com/albums/bb295/bam2002/VW%20race%20car/DSC_0028.jpg
Also our welder has a new tow vehicle, Im hoping we can use it for the FL events..
http://i206.photobucket.com/albums/bb295/bam2002/VW%20race%20car/DSC_0035.jpg
Re: Update on the Yertle team VW and our new Tow vehicle
Facebook probably doesn't allow hotlinking.
Looks like it's coming together.  Are you going to be able to drive the thing with the roof that low???  Or is the plan to split your team into "tall" and "short" drivers?
You are right FB was the issue. Its fixed.
Actually the racing seat is low, I fit . The only close spot is how close my helmet will be to the roll cage. The foam padding will make it tight, but not bad.
Its much tighter inside than the E30.
There is alot more to do. We still need to run the cage tubing up to the front suspension mounts .
Then there is all the little stuff like the engine, brakes, gauges , kill switch and fuel system.
Minor details.
