If you use a Longacre (or other brand) 4-pole kill switch, the wiring is much simpler than even with the Pegasus switch you linked to above:
http://www.ioportracing.com/Merchant2/m … y_Code=SPS
In short, with the 4-pole switch you can interrupt the main positive battery cable and hook one end of that interrupted cable to one main lug on the kill switch and then the other leg of the cable to the other main lug. Then you can interrupt the wire that goes from your ignition switch to the fuse box and run one leg of that wire to one side of the secondary lugs on the kill switch and the other leg of that wire to the other secondary lug. The 4-lug kill switch thereby kills both the power from the battery and kills the ignition signal, thus telling the engine to turn off and ending the alternator power too.
The linked Longacre switch is $35, not $60. I found it a lot easier to use that switch than try to figure out how to wire in a $5 Harbor Freight 2-pole kill switch, although I know that can be done too. I just haven't ever seen it done and with something like that, I need to see it to know how to do it. Good luck.
