In High School I had a white 59 Baja Bug named Herbst (evil Herbie) with no emergency brake and a short in the ignition that would sometimes cause it to keep running even with the key out. Loads of fun showing friends how the car had a mind of it's own.
Till one day (Thanksgiving day 1987 in fact) I was driving along a dirt road through the woods to grandmothers house minding my own business when I hit a bump and the shifter lurched forward while the gas pedal dropped to the floor on it's own, full throttle.
YEEEAAAAAAHHH!!!!
No e-brake, cant turn it off, full throttle, can't get it out of gear you could hear me scream into the next county. Mud and dirt flew everywhere. This is the day the car got it's revised name.
Another bump and everything was normal except for my wet pants. I touched the gas and the car took off like a bat out of hell again.
Turns out the front nose-cone bushing was billet aluminum and had worn the 2 mounting holes till it busted, which let the motor drop, which yanked on the throttle cable, shifting rod, clutch cable and shorted the ignition wire to the battery feed all at the same time.
I replaced that g&@ d@#$%d mount 3 times and the nose cone once before putting a rubber mount back in. No matter what I did it kept wearing away the aluminum and led to failure within weeks. (The other 2 mounts were good).
Made me a better defensive driver, but I really only had deer, cliffs, bear and logging trucks to worry about.
I'd suggest considering a polyurethane mount, as a safety item.
"Real ZomBees prefer Bacon"
