Topic: Dahlinboysracing: car and brake info
All,
Phil and I really want to understand what happened. Here is how the car was/is set up:
Car is a 1996 Acura Integra GSR. We built it over the 2013/14 winter and have raced it 18 times in both Lemons and Chump. During the build we removed the ABS per instructions found on Honda/Acura forums and replaced the proportioning valve as recommended.
The first season (3 races)we used the stock calipers with EBC rotors and pads (yellow I think). We then replaced the front calipers with Wilwood 4 piston calipers, and ran the wilwood pads and rotors for a race or two, then went to Porterfield R4 pads, and used wilwood fluid.
When he Wilwood rotors wore out we switched to EBC rotors. Various brake ducts have been used starting with Naca duct to dryer hose, and currently homemade ducts with dryer hose.
For the last 3 years we have been using Penzoil DOT3/4 fluid. Why, we are not sure. We ran out of Wilwood and...
Before the NJMP race this year the fluid was flushed and replaced with new. Before Thompson the rotors were replaced (new EBC) and the braked bleed.
After practice at Thompson Friday the brakes were bleed again, The car was run for about 2 1/2 hours total for practice.
After the Saturday session the front pads were replaced (again with Porterfield R4) on Sunday morning. We did find on the left front the the pads were wearing unevenly, and the slides were cleaned and greased.
Some random notes:
For the first 3 winters the car was either stored indoors or in a sea container behind my shop at work. This past winter it was stored outside under a tarp in my driveway.
We had a brake light switch issue for the last couple house on Saturday, the brake lights were stuck on. Sat evening I crawled in and under the dash, a grommet that contacted the switch had come out, and we replaced it with a piece of aluminum.
Before Thompson, we replaced the radiator, and Phil noticed later that when I reran the brake ducts they were aimed at the rotors, not the calipers.
We ran the car with the exact same set up (including fluid) at Thompson 2 years ago without issue. If you were there you remember the heat.
Not sure what else is relevant. Is there a way to test brake fluid to see if it has boiled? What do we look for in the caliper or master cylinder?
The car is toast, I'm not sure I'd even reuse the cage at this point. I'm happy to answer any other questions anyone has.
Fritz
