Topic: Can't keep the Saab Cool
So, the saab has always had cooling issues. It gets warmer and warmer until we're really uncomfortable. I'm trying to wrap my head around what the best next changes should be.
Details on the current setup.
- 2008 Saab 9-5 2.3 turbo.
- Water pump was changed when the car was built and is known good. Thermostat also recent replacement and operates as expected (180deg model)
- Stock routing and hoses, the heater core is still plumbed in.
- Radiator is new and a larger all aluminum aftermarket model.
- only other thing in the stack up is the intercooler which on the saab is the same footprint as the radiator.
- there is an undertray from the bumper to the radiator to keep air from ducking under.
- custom fan shroud that seals up against the radiator with two Spal 12in 1,328 cfm fans pulling through.
- The engine bay in the saab is stupidly tight, and the fans basically blow right onto the turbo and cat with no clear exhaust path. This picture shows both, the heat shield covers the exhaust manifold and turbo, and the cat is just to the right. https://photos.app.goo.gl/nsKgtsghLpcTwDqB7
What the car is doing.
When you start the car it will warm up and sit at thermostat temp just fine with the fans going. without the fans it will climb slowly like normal and then fall off to thermostat temps almost immediately when they kick on.
When you drive it on track, it will slowly heat up as you push it until it's north of 212 and we freak out. If you back off it will come down again, caution laps it drops to thermostat temp very quickly. if I throw it in neutral and coast half the front straight it will drop 5 degrees from that alone. Today I had the car at thompson for an HPDE and after 10 minutes of max pushing it would be up above 212. if I backed off my aggressiveness about 10%-15% it would stay around 206-210. Backing off means less time at WOT, coasting a bit more. Each session it would be back at thermostat temp by the time I was rolling through the pits to my spot.
Ideally I don't want temps over 205, even better I don't want them over 200. I'm trying to figure out the best changes to make to achieve this. My ideas in the order of attack that I think would be best.
1. Better seal up between the radiator and the support. It's not bad right now, but it is not perfect. Cheap and easy to improve.
2. Evaluate the front bumper and potentially open it up a little more to get more air in.
3. vent the hood. Small rectangle cut with a raised front lip to get some low pressure and allow the air an escape path. Will likely match with whatever "ducting" I can get down into the engine bay.
4. Do stupid things like install radiator misters that are overkill and do not sort the root cause of the issue but do satisfy my desire to over complicate.
I will get this out of the way. A little part of me fears a failing head gasket, but i'm not convinced. The coolant (water) is not changing colors (other than rust orange from the iron block), it does not smell, it's not sooty. I do not see bubbles in the expansion tank when it's running. when the head gasket was failing in my subaru it had issues with creeping temps at idle, even with the fans on, the saab does not have this problem. But this thought does sit at the back of my mind. I might grab one of the test kits just to be safe.
open to any ideas, thoughts, etc.
Abandoned E36 Build
