Topic: So have I got this kill switch wiring right?
First, I DID search. All I found was a bunch of posts telling people asking for kill switch help to go search. OK, well I found some info, enough to get me to this point. Tell me if I have this right. My understanding of kill switch wiring:
1. The kill switch needs to switch more than just the main battery line. Opinions seem to differ as to whether the alternator or other lines (ignition, coil) should be cut to kill the car.
2. It is (potentially) bad to have the kill switch inline between the alternator and battery because if the switch is thrown, it can cause a voltage spike killing the alternator.
3. Some people successfully use the single pole single throw (SPST) harbor freight switch.
First question:
Am I correct in my understanding that wiring leaving the alternator connected to the battery (i.e. not putting the switch in-line on the laternator output) will avoid the potential alternator-killing voltage spike since the battery is still acting as a sink for the alternator?
Second question:
I am confused about #3: How to do you wire a SPST switch properly? Is it OK to run the battery and ignition circuits through the same switch terminals like in image "A" below? The image in my head of how it works is more like image "B" below, with a DPST switch.
Help?
